My 95 ols ciera 3.1 was driven to work and when i tried to start it for lunch it would not start.Turns over fine but there is no fuel pressure in fuel rail I held in shreader valve on fuel rail when a friend cranked over motor and no fuel was present. I tried banging on gas tank while cranking over motor,and still no start .There is fuel in tank and fuel pump fuse is good, could it be a bad relay?I know this car has a red pigtail wire you can use to prime the fuel pump, but if the fuel pump relay is bad will this pigtail work to turn pump on? Could it be a bad relay or is it going to be the fuel pump?
Feb 8, 2008 at 10:37 AM
