1998 Oldsmobile Bravada Stalls After Start
1998 OLDSMOBILE
MUHLENM
1998 Olds Bravada with 4.3 V6 Vortex 65000 miles. When i go to start the engine it will crank, fire, and run for about 5-10 secs and then stall out. After this happens the fuel gauge drops from what is in the tank to zero. Try again and the same thing happens. If i let it sit for an hour or so and come back to try again, the fuel gauge will read the proper amount and it will fire and run without a problem. This problem is very sporatic. I can go a month without a problem and then every day for a week it will happen, then go away again. Another problem that is possibly related is that my coolent becomes merky and brown. I have had the radiator flushed but the color and dirtiness has come back. Im not sure if this would throw off the coolent sensor or not.
I have changed all the plugs, wires, rotor, and distributor. Also tried injector cleaners and it still happens.
Hope you can help
Apr 24, 2007 at 2:28 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you could have a connection problem at the tank unit. The coolant does that, have it power flushed, might need a few done, but eventually it will clean up
Apr 25, 2007 at 1:15 AM
MUHLENM
How do i go about checking the connections between the engine and the tank. Should i check the fuel pressure when the starting problem is happening sometime and see if it is the correct amount?
Apr 25, 2007 at 2:43 AM
Suggested Repair
Check the fuel tank sending-unit connections for an intermittent fault. Power flush the cooling system, repeating the flush if needed until the coolant stays clean.
Conversation Summary
A 1998 Oldsmobile Bravada with a 4.3L V6 cranks, starts, then stalls after 5-10 seconds while the fuel gauge drops to zero. After sitting about an hour, the gauge reads correctly and it runs normally; the issue is intermittent. The coolant also turns murky and brown after flushing. Plugs, wires, rotor, distributor, and injector cleaner did not help. The expert suggested a connection problem at the tank unit and repeated power flushing of the cooling system.
