1997 Other Oldsmobile Models Old LSS will not start
DW327
  • 1997 OLDSMOBILE
  • 6 CYL
  • FWD
  • 115,000 MILES
Power driver seat suddenly did not work passenger seat did work. Power windows did not work. Tried it 20 minutes later seat worked windows worked started right up drove around parked. Tried it 20 minutes later would not start same symptoms. Next morning started right up. Drove but this time quit while running.
Friday, August 13th, 2010 AT 2:50 PM
KHLOW2008
  • 41,814 POSTS
Hi dw327,
Thank you or the donation.
To enable us to get the correct information, we need to know the model and engine capacity etc. If you are not sure, let us know the Vehicle Identification Number ( VIN).
Friday, August 13th, 2010 AT 3:34 PM
DW327
It is an Lss w 3.8 K
Friday, August 13th, 2010 AT 4:07 PM
KHLOW2008
  • 41,814 POSTS
Symptoms indicates an interruption in the power or grounding circuits and the only relation between the power window and power seats are the grounding circuit.
Check the ground circuit behind the left kick panel for looseness and contaminations. Remove, clean, renistall and retest.
Friday, August 13th, 2010 AT 4:26 PM
