1998 Oldsmobile Bravada Bogs When Cold
1998 OLDSMOBILE
STRATOBLASTER92
I have a 98 Olds Bravada with 151K miles, 4.3L auto. I just installed a K&N Cold Air Intake, and replaced the original AC Delco plugs with Bosch Platinum plugs. Since the mornings have been getting colder, I've noticed that if I give it just a little too much throttle, it bogs untill it gets past first gear. Once it warms up it's fine. I hear that it is because of the plugs that I have.
Thanks for your help,
Aaron
Oct 14, 2007 at 1:30 AM
CHEVY22
  • 1,375 POSTS
if you have noting else going on ike a check eng light , yes put delcos back in , its a shame after all thta work , if you decide to put the delcos in let us know afterwards
jim
Oct 14, 2007 at 1:57 AM
STRATOBLASTER92
I replaiced the plugs and all is well. Thanks for your help :)
Aaron
Oct 15, 2007 at 11:33 AM
CHEVY22
  • 1,375 POSTS
good deal , happy motoring
Oct 17, 2007 at 11:17 AM
Suggested Repair
If there is no check engine light, reinstall the original AC Delco spark plugs in place of the Bosch Platinum plugs.
Conversation Summary
A 1998 Oldsmobile Bravada with a 4.3L engine bogged under light throttle in cold weather until it got past first gear, then ran normally once warm. The owner had recently installed a K&N cold-air intake and replaced AC Delco plugs with Bosch Platinum plugs. The expert advised putting the Delco plugs back in if no check engine light was present. The owner did so and reported the problem was resolved.
