Hi all,
I've got a 1988 Cutlass Cierra 3.8L olds (60,000 miles) that I inherited from my grandfather about 10 years ago.
Its been running great for the last few years but started sputtering a couple weeks ago. I haven't changed the spark plugs so i figured it was time.
After changing the plugs it was running very rough. My son had disconnected a couple wires at the same time and I thought he had swapped a couple cables. I tried to "fix" his mistake only to find out he was right.
Now the car won't start at all and when trying to start, smoke comes out the air intake (wrong way!)
So I'm not sure if I've messed something up or if the original problem is what is causing this. Any help would be apreciated!
(PS donation on the way and more to come if I can avoid towing it to the garrage!!!)
May 19, 2007 at 4:13 AM
