1998 Other Oldsmobile Models Check Engine Light-Timing Belt?
1998 OLDSMOBILE
SPIRALL200
Engine problem
1998 Other Oldsmobile Models Engine Size unknown Front Wheel Drive Automatic 10000 miles
I have an Oldmobile 88-Year 1998 (with a little over 100,000 miles), and I was driving home from the holidays-and as I neared my home it started idling really rough and the check engine light began blinking. I live in MN and it's really cold, but the temp gauge-fluid levels, and everything else on my car were normal. I managed to get it into my parking lot, but my car shut off. Now it idles and cranks, but it doesn't turn over. I have yet to hook up an ODB-II reader to it to figure out what the code is. The only thing that I could have done to cause any problems would be having to back out of a large pile of snow and strain my engine because I got stuck. It was running fine, but after I drove it a few miles to my house it began idling rough, the check engine light came on, and then it shut off. Could it possibly be the timing belt? I know I have to take it in, but I was wondering if anyone has any idea what the problem could be.
Thank you!
Dec 28, 2007 at 8:26 AM
MERLIN2021
  • 17,250 POSTS
How m8uch snow did you back up thru? Maybe a small pile went into the exhaust? Check the muffler for water! You may even have bent a pipe...restrictions in the exhaust can cause your syntoms!
Dec 28, 2007 at 8:30 AM
SPIRALL200
Actually unfortunately it's not that simple :-( I wish it were though. After talking to a few people about it -it could possibly be my thermostat? I don't know.
Dec 28, 2007 at 8:31 AM
MERLIN2021
  • 17,250 POSTS
If you have ruled that out, lets read the codes! When the MIL flashes, it mean damage to the converter can be occuring. At this point, it may already have...
Dec 28, 2007 at 9:36 AM
