1996 Oldsmobile Bravada No Start
1996 OLDSMOBILE
DD025
has 150000 miles 4.3 v6..my problem is the engine turn over but won't start... i had the car towed to my house and it started later in the day with no problem..i changed the fuel filter and it won't start again like its not getting fuel..before trying to start after replacing the filter i turned the key to the "on" position and heard the fuel pump pressurize the system and then shut off before trying to start..since then i do not hear the pump turning on....i checked the coil and its ok...not sure what to check next...when i dump some fuel in the throttle body and step on gas pedal the car runs and then stops like it just used up what i just put in there and just cranks over...
Oct 8, 2007 at 6:38 AM
  • 75,988 POSTS
Check the fuel pressure with a gauge while key is in On position. EFI system don't like incorrect pressure especially if its a CPI spider unit Vortec set up it has to have 54-62psi, get it done and comeback with results.
Oct 8, 2007 at 6:52 AM
DD025
where do i hook up gauge to check pressure?
Oct 8, 2007 at 7:32 AM
  • 75,988 POSTS
At the driver's side upper intake plenum to the rear it looks like a tire valve that's if its a CPI
Oct 8, 2007 at 8:17 AM
DD025
thanks, i'll let you know the results tomorrow.
Oct 8, 2007 at 8:21 AM
Suggested Repair
Check key-on fuel pressure at the Schrader-style port on the driver's side rear of the upper intake plenum if this is a CPI setup. A Vortec CPI spider system should hold about 54-62 psi. If pressure is low or the pump no longer primes, continue diagnosing the fuel pump and its circuit.
Conversation Summary
A 1996 Oldsmobile Bravada with a 4.3 V6 cranks but will not start. It started once after being towed, then failed again after a fuel-filter change. The owner briefly heard the pump prime, but it no longer runs; the coil tested okay, and fuel poured into the throttle body lets it run only until that fuel is used. The expert advised measuring key-on fuel pressure at the CPI test port and comparing it with the 54-62 psi specification.
