1994 Oldsm delta 88
1994 OLDSMOBILE
LAPOTTSIE16
1994 Olsmobile delta 88, 160,000 miles
My car will "die" when I am driving under 40 mph and my foot is off the gas- I lose all power and at that point only the brakes work. Sometimes it will happen 3x a day and then not for 2 weeks. I turn the car off and it restarts every time. This has been happening for almost a year and I have brought it to 3 different mechanics. Starter and alternator are relatively new - I have checked crankshaft sensor; transmission is rebuilt. Any ideas?
May 18, 2006 at 10:42 AM
LOSONE
  • 1,616 POSTS
Do you have a check engine light on?? Have someone check your fuel presure. Also make sure you have no air leaks from the air filter to the throttke body. Good luck
May 18, 2006 at 10:44 AM
