1991 Oldsmobile Power Loss No Start
1991 OLDSMOBILE
SUSYQ47
i started my car to go to work last week.it ran real ruff.didn't seem to have the power that it had before.went to the store the next day and the top speed was about 25mpr.missed alot,went up a hill and it killed, but it did start up again. went back home, top speed was about 15 mpr.heard a real loud hissing noise, my husband looked under the car and found a hole in the pipe going from the motor to the cat. converter. now car wont start at all. turns over, but no start. what do you think, maybe injectors? thanks susyq47.[/b]
Apr 8, 2006 at 5:12 PM
KENB79764
  • 52 POSTS
my first suspect would be the cat converter. if it is plugging up it will cause these symptoms.
Apr 9, 2006 at 1:35 AM
Suggested Repair
Inspect the catalytic converter for plugging, which can cause rough running, severe power loss, and a no-start. Also repair the hole found in the exhaust pipe between the engine and the converter.
Conversation Summary
The owner of a 1991 Oldsmobile with about 180,000 miles reported rough running, missing, and progressive loss of power, followed by a loud hiss and a hole in the pipe from the engine to the catalytic converter. The car now cranks but will not start, and the owner suspected the injectors. The expert's first suspect is a plugging catalytic converter.
