1982 Oldsmobile Delta 88 O2 Connector
1982 OLDSMOBILE
RICHP43
  • 5 POSTS
would any one know where the connecter for the O2 sensor is, i have a new sensor but where is the connecter located. any help please.
Feb 28, 2006 at 5:47 AM
JPAM
  • 307 POSTS
UNDER HOOD, CENTER, LOWER ENGINE AREA, PASSENGER SIDE REAR OF ENGINE, MOUNTED IN EXHAUST MANIFOLD
Feb 28, 2006 at 5:58 AM
RICHP43
  • 5 POSTS
Maybe i should clarify- i need to know where the connector for the O2 sensor, coming from the ECU, and thanks for the info.
Feb 28, 2006 at 6:21 AM
MECHANIC116
  • 28 POSTS
Locate the 02 sensor, then follow the wire. The connector shouldn't be more than 12" from the sensor itself. (typically)
Feb 28, 2006 at 6:39 AM
RICHP43
  • 5 POSTS
Thats the whole thing i cant find the end coming from the module
Feb 28, 2006 at 6:43 AM
MECHANIC116
  • 28 POSTS
? lol....that makes no sense...are you saying it's endless? Locate the oxygen sensor...follow the wire that comes out of it until you find the connector. Don't just stop and give up if the wire goes through the firewall or into a wire loom.
Feb 28, 2006 at 6:52 AM
Suggested Repair
Locate the oxygen sensor in the exhaust manifold at the passenger-side rear of the engine, under the hood in the center lower engine area. Follow the wire from the sensor to its connector, typically within about 12 inches, and continue tracing it through the firewall or a wire loom if needed until the ECU connector is found.
Conversation Summary
The owner of a 1982 Oldsmobile Delta 88 with a 307 V8 asked where the O2 sensor connector is located. An expert placed the sensor under the hood, center lower engine area, passenger-side rear of the engine, mounted in the exhaust manifold. After the owner clarified they needed the connector from the ECU, the advice was to find the sensor and follow its wire to the connector, usually within about 12 inches, even if the wire passes through the firewall or into a loom.
