This is on a 1987 Delta 88
Thanks for your help!
Timing is not adjustable, and the computer would not fire only one plug. Have a compression test done and inspect the coils, terminals, connections, and mountings; swap coils to see if the dead plug follows a coil. Confirm plug-wire routing and condition, and check the crankshaft and camshaft position sensors. Intake backfire can also come from a slipped or broken timing chain, a hung or burnt valve, a leaky injector, or an incorrect firing order. Whether repair is worthwhile depends on cost versus mileage and overall condition.
A 1987 Delta 88 cranks but will not start after a fuel stop and backfires through the throttle body. One rear-middle plug did not fire; the ignition module tested good and a scan showed no codes. The owner asked whether timing or the electronic control module was at fault and whether the car was worth fixing. The expert said timing is not adjustable and the computer would not fire only one plug, listed possible causes including a timing-chain problem, valve damage, a leaky injector, or wrong firing order, and recommended compression, coil, plug-wire, and crank/cam sensor checks, with repair value depending on cost and condition.
