1989 SHO has poor Accerlartion
MY1989SHO
  • 1989 ALL OTHER MAKES ALL OTHER MODELS
My 1989 SHO has a promblem when I drive it and go to put the pedal to the floor it wants to sputter and misfire. I noticed that it only does it when the car is warmed up. I replaced the spark plugs cleaned the fuel injectors and had the fuel system profesional cleaned out and it still does the same thing. I thought it might be my fuel pump because when I go to start the car in the morning I have to leave the key on the ON postion until I can start the car you can hear the fuel pump turn on but if I go to start the car right away it wont start right of way I have to crank the engine a couple of times befor it will start, but if leave it on the ON postion for a 1min or 2 it will start after 2-3 cranks. Please Help
Wednesday, February 1st, 2006 AT 7:12 AM
GODBEAR839
  • 77 POSTS
Have the fuel system checked out it could be a lazy pump or a bad fuel pressure regulator. See if one of those is the cause. Have you changed the filter lately also it may be clogged that could cause the problem also.
Wednesday, February 1st, 2006 AT 8:32 AM
