1989 Oldsmobile Delta 88 AC Cuts Out
1989 OLDSMOBILE
JAMESW
Thanks in advance for your help.
For 4 years I have owned this car and it has always had this problem. It is a 1989 Olds Delta 88 Royale Brougham, 4-door sedan, 3.8L, with 65k miles.
The AC in the car intermittently cuts in and out. The air will always blow, but it randomly turns from being cold to very warm. Typically it will blow cold for 10-20 minutes, then cut off and blow warm (outside temperature) for 10-20 minutes, then it will start working again. The hotter it is outside, the less time it will blow cold air. The car was bought brand new by an older woman, and only driven 50k miles in the first 10 years of it's life, then I bought the car from her and have only packed an addition 15k miles since, so it's up to 65k miles now, but has had this problem since I've owned it.
Any information would be much appreciated! Thanks!
Mar 14, 2006 at 1:08 PM
RAYHUT
  • 134 POSTS
WOW! only 65K on a 89 car thats a good deal.ok try and replace you heater core and your thermostat see if that helps if not take it to a garage and have the ac filled with freon.
Mar 14, 2006 at 10:27 PM
Suggested Repair
Replace the heater core and thermostat. If cooling is still intermittent, have a shop check and refill the AC system with refrigerant.
Conversation Summary
The owner of a 1989 Oldsmobile Delta 88 Royale Brougham with a 3.8L engine reports that the blower always runs, but the AC intermittently switches from cold to warm air for about 10-20 minutes at a time. Hot weather shortens the cold period. An expert suggested replacing the heater core and thermostat, and if that does not help, having a garage refill the AC with freon.
