WHAT IS THE EASIEST AND BEST WAY TO CHANGE SPARK PLUGS ON THAT CAR. WHAT IS YOUR ADVISE ON THAT PLEASE !
Sunday, August 30th, 2009 AT 12:43 PM
JDL
MECHANIC
If you only have one plug wire loose at a time, you don't have to worry about labeling the plug wires. You'll probably need a rachet-- various extentions-- spark plug socket. A good set of tools helps. As far as the plugs on the backside of a fwd vehicle. The easiest way to get your arm in there, top, either end, bottom. It just depends on what is easiest for you?
