HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Cutlass
Ignition
Spark Plug
Size
1987 Oldsmobile Cutlass sparklplug
TARAH98632
MEMBER
1987 OLDSMOBILE CUTLASS
Other Category problem
1987 Oldsmobile Cutlass Engine Size unknown Wheel Drive Type unknown Automatic 165000 miles
what is the order for the sparkplugs?
Monday, February 4th, 2008 AT 11:06 PM
JOHNYPHANTOM
MEMBER
If its a v-8 the firing order would be 18436572
Friday, February 8th, 2008 AT 9:52 AM
Please
login
or
register
to post a reply.
Related Spark Plug Size Content
Is There A Trick To Reaching The Back Plug Closest To...
1997 Oldsmobile Cutlass Supreme Mileage: 96,000. When Changing The Spark Plugs, Is There A Trick To Reaching The Back Plug Closest To The...
Asked by
2CP-Archives
1 ANSWER
1997
OLDSMOBILE CUTLASS
Rear Spark Plug Removal
Hi. I Am Having Difficulty Rotating My Engine Forward To Change The Rear Plugs. The Vehicle Is In Neutral And Blocked And The Front Engine...
Asked by
rdalglei
1993
OLDSMOBILE CUTLASS
No Spark Just Stopped Running While Driving
89 Olds Ciera 2.8l No Spark No Start, Fuel System Ok
Asked by
drmenkyababa
1 IMAGE
1989
OLDSMOBILE CUTLASS
Firing Order?
Removed Heads From A 3.1 Liter Took Spark Plug Wires Off Coil Packs Did Not Mark Them And The Numbers On The Coil Packs R Not The Orginal...
Asked by
Anabell
1998
OLDSMOBILE CUTLASS
1997 Oldsmobile Cutlass No Spark
I Have A 1997 Olds Cutlass Supreme 3.1 V-6.I Have Replaced Both Senors {crank And Cam}still No Spark. Have Replaced Center Coil Pack A Month...
Asked by
cddewy44
1 ANSWER
1997
OLDSMOBILE CUTLASS
VIEW MORE
Tune up
Change the Spark Plugs 6.0L V8
Spark Plug Replacement Ford F150 5.4L
