1993 Oldsmobile Bravada running bad
1993 OLDSMOBILE BRAVADA
AWILLETT420
Engine Performance problem
1993 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
I have a 1993 oldsmobile bravada. When is cold it runs ok but when it warn it runs real bad. when i press the gas more then half way it boggs down almost like it needs plugs but i put plugs and a new distributor cap on it. the hotter the motor gets the worse it runs
May 24, 2010 at 1:09 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 24, 2010 at 1:14 PM
