1993 Oldsmobile Bravada Truck will not start! Very frustra
JCSHIPKOWSKI
  • 1993 OLDSMOBILE BRAVADA
  • 6 CYL
  • AWD
  • 188,000 MILES
Ok.I recently replaced my fuel pump, fuel pump relay and battery(twice) to make a long story short.I have a brain wracking problem with my truck. It will not start without jumping the battery. And I can hear the fuel pump engaging when I turn the key to the run position, as well as it is also turning on when I turn the truck over. The truck will sputter but will not start. I have absolutely no pressure at the fuel schrader valve when key is in the run position, but fuel does come out of schrader valve when I crank engine.I have also replaced the fuel filter as well.I have these symptoms.
SYMPTOMS:
1. Engine cranks fine but won't start.
2. Engine runs fine once started.(Err jump started)
3. Hooking up battery charger or jump starting helps get it started.
4. Turning Ign. Key On and Off several times may help get it started.(When warm out)
5. Starts soon after it was last running.(Although with some difficulty)
6. Won't start in cold weather or after sitting for 24 hours or more.
7. You can hear the pump running and it's quiet and consistent sounding.
8. No pressure at the fuel schrader valve when key is in run position, but fuel does come out when cranking engine.
Thursday, December 3rd, 2009 AT 3:08 PM
SWILLIAMS
  • 597 POSTS
I assume you also replaced the fuel filter?
If so and you still have no pressure I would suspect the pressure regulator on the injection unit has failed.
Sunday, December 6th, 2009 AT 12:37 PM
LOWERED_GMC
The fuel pressure regulator is a common problem on those engines.
Friday, January 15th, 2010 AT 8:54 PM
HOMER1967
  • 875 POSTS
Yes the regulator is a common problem on those engines but it sounds to me like injectors leaking down, what you do is block off the fuel return line and see if it buids and holds pressure then, also unplug regulator and see what if any changes that hason pressure, let us know if you need more help after you try those things. Jeff
Saturday, February 20th, 2010 AT 6:19 PM
