1997 Oldsmobile Bravada just installed a motor, runs rough
1997 OLDSMOBILE BRAVADA
125,000 MILES • 6 CYL • AWD • AUTOMATIC
FAST BOYS
I just installed the motor, everything hooked up right and it sounds like out of time, but did not mess with dist, new plugs and every thing ran fine when pulled out of other bravada
Oct 31, 2009 at 12:22 PM
  • 110,244 POSTS
HAs the check engine light come on? Was the engine from the same year vehicle? If not, did you switch sensors, injection...
Nov 28, 2009 at 5:47 AM
FAST BOYS
no the check engine light never came on, but it the distributer cap was cracked, easy fix, but hard to tell by looking at it, thank you
Nov 28, 2009 at 7:17 AM
