2003 Oldsmobile Alero wont start
EFRAIN_THEFRAM
  • 2003 OLDSMOBILE ALERO
  • 4 CYL
  • FWD
  • 60,000 MILES
My engine turns but wont start the fuel pump was replaced 3 months ago and the starter was replaced 9 months ago, I dont think that they are the problem
Thursday, February 11th, 2010 AT 10:42 PM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, February 12th, 2010 AT 4:08 AM
