Hi clydels,
Thank you for the donation.
The quad drivers are integral part of the ECM and if the ECM is replaced, there is nothing that you need to do.
Fronm the description, the possible cause could be a failing ignition switch cutting power supply to the ECM and engine components. When this hapopens, it could cause the trouble codes to be registered.
SPONSORED LINKS
Wednesday, September 9th, 2009 AT 12:43 PM
