OBD II port
MAGSENTONE
  • 85 POSTS
That is what I figured. Also, do not use anti-seize on the threads of the new plugs?
Thursday, July 12th, 2018 AT 7:44 AM
  • 52,797 POSTS
As I stated before, yes. Do not or never use that for plugs.
Thursday, July 12th, 2018 AT 8:04 AM
MAGSENTONE
  • 85 POSTS
Oh okay, did not know that. So they will not seize in the screw holes right?
Thursday, July 12th, 2018 AT 10:16 AM
  • 52,797 POSTS
No, they will be fine.
Thursday, July 12th, 2018 AT 4:02 PM
MAGSENTONE
  • 85 POSTS
Thanks Roy. Hey I believe the torque specs are 15-21 ft lbs for my car according to what Ken said in an earlier email. Can we double check because you mentioned 28 ft lbs. In your recent email. Thank you Roy.
Thursday, July 12th, 2018 AT 8:53 PM
  • 52,797 POSTS
Alldata shows 24 lbs.
Friday, July 13th, 2018 AT 4:23 AM
MAGSENTONE
  • 85 POSTS
That is interesting. Thanks anyway Roy.
Friday, July 13th, 2018 AT 12:48 PM
MAGSENTONE
  • 85 POSTS
Hey Roy, I changed my plugs and they looked pretty eroded. Two were about.050 which is factory range and two were way wide about.060 or more so that was my gas mileage and performance dropping answered. Also, I just did a 3 to 9 clock or 1/2 turn once they were threaded by hand instead of using the torque wrench, should be good huh? Seems to run a lot better. Should I change the wires as well?
Monday, July 16th, 2018 AT 1:18 PM
