I have a 1996 Ford E150 conversion van. I just had the transmission pan gasket replaced and the fluid replaced no problems noted. Now after the van has been driven about 15 miles the override off flashes on the shifting handle. Once the car is turned off and started back up the light is off but comes back on after about 15 miles again. No leaks in the transmission but a little bit of a whinning noise if going under 40 MPH.
We have a manual overdrive. Fluid level is fine, don't know what type neighborhood mechanic did repair. Filter not changed. Transmission tune up?
Saturday, October 19th, 2019 AT 10:14 AM
(Merged)
