Stalled. Cranks over. Does not start. With key on, check engine light flashes rapidly. Four times faster than a misfire code. Hooked up scanner to the OBD and it does not read anything. Assuming the PCM was bad, I replaced it with the proper one and supposedly programmed with my VIN before installed and still nothing. Any ideas?
Thanks, Tom
Thanks, Tom
Apr 15, 2017 at 1:34 AM
