Not starting
FRANK9657
  • 17 POSTS
6 cyc and I cannot shift my car out of park and some gauges don't respond unless I unplud the throttle body and then gauges work
Thursday, February 4th, 2016 AT 12:28 PM
SATURNTECH9
  • 30,869 POSTS
That sounds a lot like a bad body control module.I have seen them go bad and cause those symptoms and cause you not to able to talk to the ecm.I have never tried unplugging the throttle body to see if anything changes from doing that.I have a whole stash of old bcms for testers with the symptoms of what they doing when I changed them to see what changes when I plug them in. What you say about the gauges and not being able to get it out of park are all known things I have seen happen when bcms on those cars go bad.
Thursday, February 4th, 2016 AT 1:03 PM
FRANK9657
  • 17 POSTS
Where is the BCM located how much is for a new replacement
Thursday, February 4th, 2016 AT 1:08 PM
FRANK9657
  • 17 POSTS
Any way to test the bcm
Thursday, February 4th, 2016 AT 2:48 PM
SATURNTECH9
  • 30,869 POSTS
The bcm is on top of the glove box you have to remove the glove box and it's attached to the glove box.I have also seen bad bcms cause no starts when the gauges etc are inop. Then when the gauges work the car starts. Bcms are close to 300 plus they have to be programmed.I have seen a repair service on eBay that is much cheaper plus it keeps all your day mileage programming etc. You mail your bcm to them and they fix it and mail it back. It was very reasonable verus buying a new one and having it programmed. As far as testing them we never tested them at the Saturn dealer we just swapped it for one of our old ones we replaced and saw if it changed the symptoms. It's very common for them to go bad that's why I asked about the symptoms. Which you mentioned the ones I asked you about. You may have more than one problem but it sounds like you have a bad bcm.
Thursday, February 4th, 2016 AT 8:58 PM
FRANK9657
  • 17 POSTS
You got the info so I can mail the bcm for repair
Friday, February 5th, 2016 AT 4:45 AM
SATURNTECH9
  • 30,869 POSTS
1-866-573-2740 that's the phone number for the bcm repair service call them to talk to them about your bcm.
Sunday, February 7th, 2016 AT 7:27 AM
FRANK9657
  • 17 POSTS
I found a place on line the say it sounds like the ecm not the bcm the say for 80 dollars each they and test both of them let me know which is bad and repair it for 300 that way I don't have to get them preprogrammed if I get a new one.
Sunday, February 7th, 2016 AT 7:53 AM
SATURNTECH9
  • 30,869 POSTS
Here's my problem with that theory not being able to take it out of park is controlled by the bcm not pm. Also if the car will only start when the gas gauge works another symptom of a bad bcm.I have replaced tons of bcms on those cars or tons of ecms. The number I gave you the guy charges 165 to repair the bcm. Go to eBay put in the search box Saturn bcm repair it will come up. Read the listing and symptoms and then post back to me and tell me what you think.
Sunday, February 7th, 2016 AT 8:00 AM
FRANK9657
  • 17 POSTS
I called the place for the bcm repair I been trying to find out were and how to remove the bcm so I can send it in any help thank
Thursday, February 11th, 2016 AT 2:37 PM
SATURNTECH9
  • 30,869 POSTS
I told you where the bcm was it's mounted to the glove box insert. There are multiple philps screws on the inside of the glove box. Also take all the screws that hold the glove box door out. There is also a AC duct hooked to it if memory serves right. It's been a lot of years since I have replaced one.
Thursday, February 11th, 2016 AT 9:12 PM
ERNIE RUIZ
I have this exact same problem. Did you guys ever come up with a solution? Was it the BCM?
Sunday, June 23rd, 2019 AT 11:55 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,235 POSTS
It looks like they went back and fourth for a while. can I ask if you have any codes and can you hear the fuel pump run in the tank when the key is in the on position?
This guide can help us get started:
Monday, June 24th, 2019 AT 1:47 PM
