A/C not blowing cold air
DONNA BEASLEY
  • 2007 TOYOTA COROLLA
  • 95,500 MILES
My air conditioner was not blowing cold air all the time. I had Freon put in it and it was blowing warm air and sometimes it blows cold air, but never blows cold air all the time.
Help please!
Monday, October 19th, 2020 AT 6:00 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 50,135 POSTS
When the cold air stops can you use a flashlight with the engine running and the ac on check to see if the compressor clutch is turning, this will help us narrow down the problem.
Here is a guide that will help
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
ALI.ALVI
  • 54 POSTS
  • 40,000 MILES
The A.C of my car is Not cooling the car on idle RPM although gas pressure is fine.
Its probably freezing up due to air and moisture forming ice and blocking of the orifice tube-Get the system evacuate and see what happens
FAHDASLAM
  • 27 POSTS
  • 70,000 MILES
AC of my car is not cooling at idle RPM when the car moves it cools well. Compressor is changed and condenser is in good condition. My last compressor got burned coil and that was too not cooling at idle. Now that compressor is changed and whole system is cleaned by mechanic still am not having cooling at idle.
SATURNTECH9
  • 30,869 POSTS
What are the high and low pressures at idle? Also is the ac condenser fan working? If your not moving and raise the rpms up will it cool then?
Related Air Conditioner Not Working Content
Fix an Air Conditioning Not Working Video
VIDEO
