Okay. This is sounding more and more like a faulty coil. So, if it failed these tests then the instruction was to replace the coil? Is that correct? Meaning on the testing did it tell you to replace it? If so, let's go for it.
The only other thing that can cause this is the control module but based on all this testing it points to a coil.
SPONSORED LINKS
Thursday, April 21st, 2022 AT 7:35 AM
NEGGEN
MEMBER
Sounds good. I'll throw a new one in this weekend and see what happens. Thanks!
Thursday, April 21st, 2022 AT 3:48 PM
NEGGEN
MEMBER
Put in a new coil and it fired right up and runs like a champ! Thanks a lot for the help I learned a lot from this.
Friday, April 22nd, 2022 AT 7:43 PM
MECHANIC
That is great. Thanks for the update and I'm so glad that you figured that out. You did a great job in the testing and walking through this, and I am sure that this post will help others to do the exact same thing.
