No start
  • 52,797 POSTS
Not good.
Does the orange wire have power?
Monday, January 20th, 2020 AT 6:57 PM
VICKY LAMPMAN
  • 29 POSTS
Yes orange has voltage, on and start. Checked yellow again.41 volts this time started and.14 on position then.78. Seems voltage all over the place?
Tuesday, January 21st, 2020 AT 12:23 PM
  • 52,797 POSTS
It should be battery voltage. You need to replace the ignition switch.
Tuesday, January 21st, 2020 AT 12:34 PM
VICKY LAMPMAN
  • 29 POSTS
Ah, I was thinking same thing. Looking at diagrams you sent. Would that be most likely the problem with all 3 those fuses? Okay I will let you know how that goes. Thank you
Tuesday, January 21st, 2020 AT 3:21 PM
  • 52,797 POSTS
The red wire feeds the fuses, not the yellow.
I would replace the switch and then we can proceed.
Tuesday, January 21st, 2020 AT 6:44 PM
VICKY LAMPMAN
  • 29 POSTS
Hi, got ignition switch replaced, still have like.07 volts key turned on yellow wire at ignition when key turned to crank volts went to battery volt. On the fuses Using power probe now rr htd ind comes as grounded both points but no volts, A/C switch when applied continuity the blower came on otherwise volts like.07 and start fuse shows drop volts as well. What are your thoughts on this? Thanks
Sunday, January 26th, 2020 AT 11:28 PM
  • 52,797 POSTS
The yellow wire is good. It should have a battery voltage in the start position only.
The red wire needs power to the fuses. If there is no power to the fuses, the red wire is open somewhere.
Monday, January 27th, 2020 AT 12:59 PM
VICKY LAMPMAN
  • 29 POSTS
Hello, I might know something about electrical by time I am done here. So I found that I am chasing the pink wire seems to be the problem, it has battery voltage coming off ignition, but losing it somewhere before fuse panel. The blower, relays are all good, the pink wire to them has only.34 volts as does fuse panel am still following harness under driver side trying to find where volts change at. Before I keep going am wondering if it could be another component causing this to check, before I have wiring harness all apart. Is there another diagram maybe showing from fuse box connectors that might help. Thanks again
Saturday, February 1st, 2020 AT 8:07 AM
  • 52,797 POSTS
The red wire is the one you need to chase.
Saturday, February 1st, 2020 AT 11:48 AM
VICKY LAMPMAN
  • 29 POSTS
Can you explain please? Additional information helpful.
The red seem fine. Hmm
Saturday, February 1st, 2020 AT 12:15 PM
  • 52,797 POSTS
Do you have power to the fuses? The fuses you do not have power are controlled by the red wire, not the pink.
Saturday, February 1st, 2020 AT 12:20 PM
VICKY LAMPMAN
  • 29 POSTS
When I back probe connector at ignition and connector to 10A a/con sw fuse they all check out fine except the pink one getting only.34 volts. And at the blower relay and blower motor the pink one also is only.34 volts. But fan blower starts when I apply power to the pink wire through fuse and at relay and blower.
Saturday, February 1st, 2020 AT 1:21 PM
  • 52,797 POSTS
OK, then you also have an issue with that wire as well between the ignition switch and the fuse block.
Saturday, February 1st, 2020 AT 1:25 PM
VICKY LAMPMAN
  • 29 POSTS
Hi Roy, whoa I just found something I didn't before. I was tracing wires through harness that goes out to engine by firewall under dash and cleaning. Went back to check fuses and realized they all have correct voltage with negative battery cable off and when negative cable put back on is where A/C sw 10A fuse loses voltage, now that seems to be only fuse not getting enough to power is on my A/C system. The control panel lights and can move fan symbols and temperature work, just not coming on. Thanks
Sunday, February 2nd, 2020 AT 11:05 AM
  • 52,797 POSTS
You cannot have power with the battery cable off. Please explain?
Sunday, February 2nd, 2020 AT 2:44 PM
VICKY LAMPMAN
  • 29 POSTS
Hi sorry, I have battery connected I clamped power probe to battery terminals and check voltage A/C switch fuse still has low voltage. I take negative battery cable off check voltage and I get battery voltage at that fuse, when I put negative cable back on and voltage drops down again.
Sunday, February 2nd, 2020 AT 7:46 PM
  • 52,797 POSTS
I do not understand what you are doing.
You can't have any voltage when the battery cable is removed.
Sunday, February 2nd, 2020 AT 9:14 PM
VICKY LAMPMAN
  • 29 POSTS
Nevermind I caught what I was doing.
Monday, February 3rd, 2020 AT 6:49 AM
  • 52,797 POSTS
Keep me updated.
Monday, February 3rd, 2020 AT 7:11 AM
