Car died at stop light. Replaced timing belt, Belt was missing teeth but not broke. Matched marks, replaced cam sensor, crank sensor. Spark plugs, air filter, and fuel filter. ECM coded on crank sensor prior to repairs. After repairs, I've used scanner to clear code, un hooked battery terminal for 15 minutes. No new codes. Past data can be pulled from ECM but no help. Compression is 180lbs - 200lbs in all cylinders. No spark or fuel.
Prior to dieing car had rough idle and low idle.
SPONSORED LINKS
Thursday, November 6th, 2008 AT 12:00 PM
