no sound from radio, although door chimes still work
2004 CHEVROLET IMPALA
60,000 MILES
DANTHEMANDOTCOM
I have a 2004 Impala with an aftermarket stereo/CD player that was up until last night working fine. When key us in ignition and door open, the door chimes still work fine, just nothing coming from AM/FM or CD. I have never installed anything electrical before so I am kinda at a loss of where/how to troubleshoot this...
Oct 26, 2015 at 3:48 AM
  • 55,224 POSTS
Hey Danthemandotcom,
Do the lights on the radio come on?
Best, Ken
Nov 2, 2015 at 8:40 AM
DANTHEMANDOTCOM
Yes indeed, radio does get power. Sound has been working intermittently and seems to need to "warm up", (I live in Alaska, and it's getting below freezing already) and will crackle a bit and eventually clear up and work fine, til usually the next morning when I go to warm the car it will be silent with power to the radio, with the exception of the chimes, those still work. I have noticed wetness in the rear passenger floor, and have recently had a coolant flush/ heater core backflush because of overheating, before that water pump and then elbow shaped pipes/tubes replaced that had deteriorated through... not sure if the shop messed with the blower motor area because they did call while it was in the shop saying it was "acting up and going out" and on another call later that day said they had gotten it working again. I read somewhere that the wetness at the rear floor may be all relative. Hope that makes sense, LOL. Thanks.
-Danny
Nov 2, 2015 at 9:20 AM
  • 55,224 POSTS
Yep just as fast summer gets here, its gone ,,, most likely the radio is going bad which is common problem with aftermarket units. The water/moisture doesn't help matters but even if you get that fixed the damage has been done, it might be time to replace the unit, hope this helps, stay warm! :-)
Best, Ken
Nov 2, 2015 at 11:42 PM
