Also, I began my automotive career as an installer. I'd still strongly recommend running those wires down the center of your vehicle. You can insert the wires under the carpet behind the dash, then fish them through the back with a coat hanger. And cutting a small hole in the carpet doesn't hurt anything, so long as you do it correctly. Patience!
The reason I say this, your wires get very cold and brittle running through the kick panels, they get chaffed and corroded from moister (kicking your feet on the kick panel).
When ever you see a professional wiring a sound system for competition, you NEVER see them running wires through a kick panel. So there must be a reason why, right?
SPONSORED LINKS
Wednesday, January 13th, 2010 AT 9:10 PM
