No signal from coolant temperature sensor to E-Fan
  • 52,797 POSTS
I just went through several hundred TSB bulletins, and none have any reference to this issue.
There is only the sensor, the wiring, and the ECM.
The sensor has been replaced two times. The wiring is good proven by removing the connector and the ECM triggering the fan.
Tuesday, January 18th, 2022 AT 4:19 PM
SOMBOYV
  • 13 POSTS
Yes, I'm stuck not sure what more I can do might replace the ECM or just take it to the mechanic shop. Or just driving it with the A/C on low just so the fan can work. Is there a bypass kit for the fan?
Tuesday, January 18th, 2022 AT 4:49 PM
  • 52,797 POSTS
I would drive it with the A/C on and adjust your temperature as needed until you make a decision.
No, not that I know of.
Wednesday, January 19th, 2022 AT 3:38 AM
