No reverse?
TIGER2020
  • 1998 FORD EXPLORER
  • 6 CYL
  • 84,000 MILES
Yesterday, as we were backing out of the driveway, the truck just stop going in reverse after goiing in reverse for about 20 feet. It will go into drive, but not reverse.
Tuesday, December 22nd, 2020 AT 8:46 AM (Merged)
JGAROFALO
  • 489 POSTS
When driving forward, does the transmission shift through all of the gears? Does it operate normally otherwise? If so, you probably have a broken rear band. This would be an internal problem that would require transmission disassembly to repair.
STEVO57
Transmission problem
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic
no reverse-forword gears good
  • 31,937 POSTS
Hi there,
This is a common problem, I see this question posted here often, nearly all are a internal transmission mechanical failure, you should get this to a transmission specialist, toe it in do not drive as you may do more damage, first thing that they should do is scan the ECU and make sure that it is not an electrical problem, best to make sure first.
Mark (mhpautos)
GSKODE
Good afternoon, I just had my transmission repaired at a local shop. The reverse band had broke. Now it is slamming into reverse. The shop says that it has something to do with a ground problem between the computer and the tranny. Could this be the problem or is he BSin me?
  • 109,885 POSTS
Before I read that you had it repaired, I was thinking of the tcm (Trans Control Module). However, he may have not properly adjusted the band that he replaced. Since the work was just done, I would ask him to recheck that he properly adjusted the band.
Let me know what you find.
GSKODE
The transmission was repaired by a proper tranny shop, so I would imagine that the band was adjusted properly. Where is the trans control module located?
  • 109,885 POSTS
I found this TSB. Take a look at it and let me know if you experience any of the problems.
TSB data for: 1998 FORD EXPLORER
Bulletin Number: 9987
Sequence Number: 621290
Date: 19990527
Component Name: 103100 POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Make: FORD
Model: EXPLORER
Year: 1998
Summary:
SOME VEHICLES MAY EXHIBIT HARSH DOWNSHIFT FROM 3RD TO 1ST GEAR WHILE STOPPING, HESITATION AFTER ACCELERATION FROM STOP AND / OR LACK OF POWER AFTER ACCELERATION FROM STOP ON VEHICLES WITH 4.0L OR 5.0L ENGINES.
As far as the TCM, I believe it is mounted on the transmission.
Tuesday, December 22nd, 2020 AT 8:47 AM (Merged)
JACK242
  • 6 CYL
  • 95,000 MILES
Recently, my car can't reverse smoothly, specially in morning, first time reverse car. I have to wait 20-30 seconds to get revese force after engine starts. After I drive a while, if I try to reverse again, it is fine, or just wait 1-2 seconds to get reverse force.
  • 109,885 POSTS
Hi:
Chances are the o-rings and seals are getting hard. As a result, the trans fluid bypasses the seal. Thus, it takes longer for it to shift. As the vehicle warms us, they soften and start working again.
Ask at the local parts store of they have something that will take care of it. Let me know what you find.
Joeeeee
SPARKII3X69
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic 140k miles
my truck has no drive but it will go into reverse right away
  • 109,885 POSTS
Has the check engine light come on? Also, is the ATF full and clean?
Let me know. THis sounds like an internal problem, but I just want to know about the questions I asked.
JOE BUNNER
  • 3.0L
  • 6 CYL
  • 4WD
  • 260,000 MILES
There was nothing wrong with the vehicle at all we heard a grinding noise on the way back from Walmart in the rear end of the car or so it seemed from the inside we get home and Park next morning we get up to back out of the driveway the car starts backing up and then slam stop as if it hit something will not going to reverse it all. The car will still go forward but it will not go in reverse what do I need to fix this problem besides taking to a transmission shop
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
It sounds like the rear differential has gone out. To be sure lets jack up the rear of the vehicle and remove the drive shaft. here are two guides to help you do the job:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
and
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
once the drive shaft is off see if you can turn the pinon yoke it should move both ways easily. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
SHANETHIA08
1998 Ford Explorer Four Wheel Drive Automatic
Can please tell me what wron with my truck it won't let me back up?
Tuesday, December 22nd, 2020 AT 8:48 AM (Merged)
MIKE H R
  • 3,094 POSTS
I could try tohelp but need more information. Does it drive all right going forward? When put in reverse what does it do and does it make any noise. How long has this been going on? Have any work been done on the transmission? With you just saying it won't back up does not give me a lot to work with.
Get back to me.
Mike
