no gas going to the engine
260,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
ECLIPSE270
My car wouldn't fully start like it wasn't getting any gas. It acted like it wanted to fire up, but that was only the gas in the lines being ran out. It sat for four days and then started up. Drove it the next day and it stopped again with the same results. What could be the problem?
Apr 21, 2016 at 12:55 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it.
Apr 21, 2016 at 2:29 AM
ECLIPSE270
Thanks for the advice
Apr 21, 2016 at 10:05 AM
  • 55,732 POSTS
Hey Eclipse270,
It could be the fuel pump that is failing, here is a video that lets you know what you are in for to change it. Its not the same car but basically the same procedure.
https://youtu.be/h_VHxBmecj8
Let us know what you find
Apr 21, 2016 at 10:16 AM
