Engine not running
JOETRACYJOETRACY
  • 25 POSTS
Thank u so much. It's installed now. Still no fire. Unplugged cam sensor. Inspected plug. It's clean. With volt meter I checked for power. 5 volts then I checked the ground at the plug. Still received 5 volts. As I was checking power I even shook the harness to see if maybe I had broken wire or short. Still constant 5 volts. Any ideas nkw as to why still no fire at spark plugs? Also I replaced both ignition coils, they are new. Only thing I can come up with is bad camshaft position sensor. What u think? Forgot to tell u. I scanned the truck and received a code. It was P0320 if this helps. I almost at end of my ropes.
Thursday, August 3rd, 2017 AT 4:43 PM
JOETRACYJOETRACY
  • 25 POSTS
I know u are very busy. Just wondering if you had a chance to take a look at my post above where I stated results of testing electrical connections and the code I had received when I scanned the truck. Please help
Friday, August 4th, 2017 AT 1:52 PM
STEVE W.
  • 15,276 POSTS
P0320 is crankshaft sensor related. Either the wiring is faulty, or the sensor is bad. As they are known for failing you might try a replacement unit.
Testing for bias voltage is OK but you won't actually be able to see if either sensor is working because they don't use a constant voltage, they send a digital signal that can be seen with an oscilloscope, but not with a meter.
Friday, August 4th, 2017 AT 3:57 PM
MICHAEL PECK
What was the ending result of the cause for no spark? Do we have a verdict.
Friday, May 24th, 2019 AT 8:04 AM
STEVE W.
  • 15,276 POSTS
Sorry, never had a reply back as to the results.
Friday, May 24th, 2019 AT 9:32 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,217 POSTS
We will need to pick the thread back up, can you tell us what you have tried? Have you check the fuses?
Sunday, May 26th, 2019 AT 12:46 PM
MICHAEL PECK
I have pictures to post if you want them.
Tuesday, May 28th, 2019 AT 6:31 PM
STEVE W.
  • 15,276 POSTS
Vehicle information and what you have tried or tested as a start, pictures or videos of the problem are always good.
Tuesday, May 28th, 2019 AT 8:08 PM
