Do I need a starter?
CARADIODOC
  • 33,916 POSTS
You hit it. It's a coincidence. Or, ... The starter felt sorry for the amp!
If you have the little silver Nippendenso starter, it is common for them to develop worn solenoid contacts. It will crank the engine if you cycle the ignition switch to the "crank" position a few times. The contacts can be replaced seperately, but most people just replace the entire starter.
Caradiodoc
Monday, August 31st, 2020 AT 1:07 PM (Merged)
ZOG1974
  • 46 POSTS
  • 2005 CHRYSLER TOWN AND COUNTRY
  • 3.8L
  • V6
  • 125,000 MILES
Had battery checked and it is good, just put in new starter. If I let the car sit for a day then I turn the ignition I hear only fast clicking, but then it will jump start. Not sure what the problem is.
  • 109,885 POSTS
If you hear a fast clicking sound, that usually indicates the battery is too weak to turn the engine. With that in mind, you need to check a couple things for me. First, why is the battery going dead after sitting? You need to check for what is called a parasitic draw on the battery. Basically, even though everything is turned off, something is still drawing enough power to ruin the battery. Follow this link to check,
https://www.2carpros.com/articles/car-battery-dead-overnight
If I misunderstood what is happening, let me know. Also, you mentioned if it sits a day this happens. The link indicates over night. However, it is the same principal involved. It may just be a slower draw.
As in all electrical concerns, make sure the battery terminals are clean and tight.
Let me know if this helps.
2CP-ARCHIVES
  • 4,540 POSTS
  • 100,000 MILES
In the past two weeks, my car has spells of not starting. I have checked the battery. It is good, even though when it won't start it goes clickclickclick. Took it to the repair shop after trouble lights started coming on in the dash and the engine started surging. He replaced a cable in the left passenger door and said that should solve my problems. Got it back Friday. Today, (Tuesday) the car again would not start. I have spent thousands on this car and it never seems to go a month without a major repair bill. What could be wrong now?
CARADIODOC
  • 33,916 POSTS
Is that multiple rapid clicks or one single rather loud clunk each time you turn the ignition switch to "crank"? If it's a single clunk, it has worn contacts inside the starter solenoid. Those can be replaced for less than $20.00 but most people just replace the entire starter. Many hardware stores and farm supply stores have the repair kits that have more parts than you need for any one starter.
BILLPENCE
  • 2004 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • FWD
  • 60,000 MILES
Clicks when trying to start - is ok when trying a second time - battery or starter?
  • 109,885 POSTS
What happens the first time? Does the starter not work?
Could be the starter, starter relay, transmission range switch and ignition switch assuming the battery and connections are good.
Monday, August 31st, 2020 AT 1:08 PM (Merged)
