REMOVAL - 3.3/3.8L
1.Release hood latch and open hood.
2.Disconnect and isolate the battery negative cable.
3.Hoist and support vehicle on safety stands.
4.Remove nut holding B+ terminal to starter solenoid.
5.Disconnect solenoid connector from starter.
6.Remove bolts holding starter to transaxle bellhousing.
7.Remove starter from bellhousing.
8.Separate starter spacer from transaxle bellhousing.
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Sunday, October 26th, 2008 AT 8:29 AM
