2001 Chrysler Town and Country starter
MIKEY121
  • 2001 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • FWD
  • 103,000 MILES
Put new engine in it and I think I have something hooked up wrong or missing it wont get a spark really need an electrical diagram to view.
Saturday, October 16th, 2010 AT 4:52 PM
BMRFIXIT
  • 19,053 POSTS
Check for codes
make sure crank sensor is plug d
Check for codes
key on engine off do you have check engine light on you should if not recheck fuses and wiring
with key on engine cranking check engine light should go off if not suspect and check crank sensor
what diagram you are looking for
Saturday, October 16th, 2010 AT 4:59 PM
MIKEY121
Need the diagram that shows the wiring for the starter to make sure I got everything hooked up right
Saturday, October 16th, 2010 AT 5:04 PM
MIKEY121
Could there be an automatic shut off for oil pressure
Saturday, October 16th, 2010 AT 5:06 PM
BMRFIXIT
  • 19,053 POSTS
Does it crank?
GM use oil pressure switch to keep fuel pump running after engine start
Chrysler don't
Saturday, October 16th, 2010 AT 9:09 PM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_1_31.jpg
Saturday, October 16th, 2010 AT 9:30 PM
