1990 Nissan Hardbody Hot Start Knock
GRISSOM75
I have a 1990 Nissan Hardbody 4cyl Manual Trans w/ 160,000 miles. You can let this truck set for a week or longer and when you start it you hear just a little noise from the top of the engine. But if you drive it every day, It makes lots of loud knocking sounds when you start it for about 5 seconds. Its worse if you kill it, wait about 5 min. and start it back. If this truck sets up for a couple of weeks without being started, It hardly makes any noise. Thats weird to me, Can you help?? PS: lucas doesn't help.
Dec 29, 2006 at 10:11 AM
  • 75,988 POSTS
Is this a K24 engine? Do this 1st have the engine flush thoroughly and I mean thoroughly to clear the galleries. change oil and filter and see what happens it might help. BTDT on this problem a lot of times and its a wild one. However am willing to help you.If you remove the valve cover you'll know what am talking about and then we'll proceed.
Dec 29, 2006 at 5:03 PM
Suggested Repair
Thoroughly flush the engine to clear the oil galleries, then change the oil and filter and recheck the hot-start knock. If the noise remains, remove the valve cover for further inspection.
Conversation Summary
The owner of a 1990 Nissan Hardbody 4-cylinder reports loud knocking for a few seconds on hot starts after daily driving, worse after a short shutdown, but little noise after the truck sits for weeks. An oil additive did not help. The expert recommends a thorough engine flush to clear the galleries, followed by an oil and filter change, with valve-cover inspection if needed.
