1989 nissan d21 pickup 6 cyl. 4wd 5 speed
1989 NISSAN TRUCK
MATTYICE89
this vehicle will not turn over the battery is good it has a new starter and a new starter relay, when u try to start it all u hear is a clicking noise !!!!but if you pop the clutch its starts every time and runs perfect !!!! can u help me !!!i also changed the ignition switch !!! Also the batterys ground wire is kind of corroted could tha be the main cause of the problem !!!! thanks for any help!!!
Jan 23, 2007 at 3:08 PM
[quote:9ec844ac85="mattyice89"]this vehicle will not turn over the battery is good it has a new starter and a new starter relay, when u try to start it all u hear is a clicking noise !!!!but if you pop the clutch its starts every time and runs perfect !!!! can u help me !!!i also changed the ignition switch !!! Also the batterys ground wire is kind of corroted could tha be the main cause of the problem !!!! thanks for any help!!![/quote:9ec844ac85]
Bad clutch switch and real bad connections will do it.
Jan 24, 2007 at 12:19 PM
