1997 Nissan Truck TRUCK WON'T START
ROB64
  • 1997 NISSAN TRUCK
  • 4 CYL
  • 4WD
  • MANUAL
  • 11,000 MILES
I HAD PROBLEMS A COUPLE OF MONTHS BACK I WOULD COME TO A STOP SIGN OR LIGHT AND IT FELT LIKE THE TRUCK WANTED TO STALL. SO I GAVE IT A TUNE UP CHANGED PLUGS WIRES DISTRUBTER CAP OIL FILTER AIR FILTER GAS FILTER, STILL WAS HAVING PROBLEMS. THEN A COUPLE OF TIMES THE TRUCK WAS COLD AND I HAD A HARD TIME STARTING IT IT WAS TURNIG OVER BUT HAD A HART TIME STARTING THERE IS A NEW BATTERY IT IT TOO. ONE TIME AT WORK IT REALLY HAD A HARD TIME STARING FOR TEN MINUTES I WAS TRYING FINALLY IT STARTED A LOT OF SMOKE CAME OUT OF THE EXAHUST AND FROM THE ENGINE. THEN JUST YESTERDAY I WENT TO START IT BEFORE WORK AND NOTHING IT IS CRANKING OVER BUT WON;T START AT ALL.
Tuesday, June 2nd, 2009 AT 1:55 PM
TEAG
  • 158 POSTS
You could try adjusting the idle. Just loosen the distributor cap and turn it while the truck is running. You should hear a change. Just speed the idle up a little bit and see how that works. Hope this helps ya out.
Wednesday, July 1st, 2009 AT 9:07 AM
ROB64
I wish I could try and adjust the idle but I can't get it to start at all. I even hooked it up to a auto code scanner no codes came up. It has spark and it getting fuel. It's cranking over but won't start
Wednesday, July 1st, 2009 AT 9:16 AM
COOL GUY
Check your fuel pump pressure.
Saturday, October 3rd, 2009 AT 11:07 PM
