1997 Nissan Truck Rough Idle/Stalls
CLIFFO
  • 16 POSTS
Dear Rasmataz,
Thank You for your patience and expertise. I will order a new pressure regulator and install it and report back to you later in the week. Thank You Again!
Sunday, March 15th, 2009 AT 11:31 AM
CLIFFO
  • 16 POSTS
Dear Rasmataz,
I've installed the new pressure regulator and observed the following conditions:
1.) Fuel pressure never fluctuated. It stays high at 45 psi with the vacuum hose attached. It never went to 34 psi like it's supposed to 2.) The engine idles somewhat smoother after it is warmed up but at times wants to stall/idle stumbles, but never does 3.) The engine stills revs up on it's own (up to 1,300 rpm, then down to 900 rpm)but the incidents are fewer and not as high revving.
Any thoughts? Thank You!
Friday, March 20th, 2009 AT 6:56 PM
Recheck the IACV-AAC valve and the return line
Saturday, March 21st, 2009 AT 4:50 AM
CLIFFO
  • 16 POSTS
Dear Rasmataz,
The IACV-AAC is a brand new part so I know it works and is clean. The return line is also clear. I will change the fuel filter and see how that goes. Maybe there's something there that's causing a partial block of the line. I'll report back to you when I'm done.
Thank You Again!
Saturday, March 21st, 2009 AT 10:24 AM
MARKAM CAMPBELL
Just because a part is new doesn't mean it is a good part I changed a starter 9 times on a suberu justy because of defective starters from the manurfactures
Saturday, July 4th, 2009 AT 12:33 PM
BRANDON WILSON
I have a 97 Nissan 2.4 5 speed love the truck but tired of the problems ever since I bought it it has cut out an ran rough it's almost like riding a bucking bull has a huge dead spot an cuts in an out sometimes it runs fairly decent but then it starts acting crazy I've changed plugs wires distributor cap rotor button throttle body an just put a motor in it cause my old one spun a bearing please help I've spent too much time an money
Sunday, October 27th, 2019 AT 11:40 PM
STEVE W.
  • 13,577 POSTS
Brandon, could you please ask this as a new question? Add in any information you can, like anything you have done. That would put you on the top of the list. Any info like a fuel filter, pump or any testing. Did the bucking also happen with the old engine, things like that.
Monday, October 28th, 2019 AT 2:37 AM
