my truck is a 1996 hardbody 2.4 cyl it has rough idle i have changed plugs, wires,dist cap removed the converter cleaned the egr valve, and the idle air control valve it had alot of carbon in it ,cleaned the throttle body .to no luck/and the fuel milage is awful and changed the rotor button, i was told it could be the fuel pressure regulator, or the iac valve its kicking my but can you help
Aug 20, 2010 at 2:01 AM
