transmission won't engage
1993 NISSAN TRUCK
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
DINGLEBERRY
The shifter will not engage in any gear. It moves freely. I can push the shift lock button on the left side of the steering column and the transmission will engage temporarily but then the problem recurs. Is this a mechanical problem or a problem with the shift lock mechanism? Thanks
Aug 14, 2009 at 1:15 PM
This sounds like a mechanical issue that could be related to the fluid level or condition.
I am not sure why it would engage temporarily but that doesn't change the steps we need to take.
Here is a guide that will help with checking the fluid and filling it if needed:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
However, if the fluid is not in good condition, then we need to change it so let's follow this guide to get that done:
Lastly, we need to check for codes and find out what is there.
If we have sensor issue, then we should have some codes and this guide will help pull codes:
Please run through this info and let me know what questions you have.
Thanks
Mar 26, 2022 at 12:14 PM
