HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Truck
Engine
Symptoms
Not Running
1991 Nissan Truck truck wont start
RACHGIRL
MEMBER
1991 NISSAN TRUCK
4 CYL
2WD
MANUAL
120,000 MILES
After fixing flywheel engine turns over but wont start
Friday, October 17th, 2008 AT 5:59 PM
BLACKOP555
MECHANIC
Time to go back and double check everything you have touched. Sensors, wiring harness, everything.
Make sure they are properly adjusted and that they are hooked up.
Is the crankshaft sensor on the flywheel?
Also did you disconnect the battery during this?
SPONSORED LINKS
Saturday, October 18th, 2008 AT 9:40 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Truck Will Not Start, Unless Battery Charger Is Hooked...
When Truck Starts Key Has To Be Held In Start Position For Approximately 30-45 Seconds. Then The Truck Will Go Ahead And Run, But If Shut...
Asked by
StubyBeekeeper
1991
NISSAN TRUCK
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1991 Nissan Truck Truck Wont Start
I Have A 1991 Nissan D21 4x4 V6, Truck Was Sitting Idiling Then All Of A Sudden It Stopped Running. Went To Go Restart The Truck And It...
Asked by
colinw6969
1991
NISSAN TRUCK
1991 Nissan Truck Starting Problems
Heres One For Ya Trucks Been Spitting And Sputring For A Few Weeks But Still Starting Now I Have Fuel At The Fuel Rail But Wont Start Unless...
Asked by
JamGer01
1991
NISSAN TRUCK
1991 Nissan Truck
I Have A 91 Nissan Pickup. No Major Problems Really. I Had The Air Converted Over So It Could Be Charged About A Week Ago. Ran Fine....
Asked by
chinflip4u
1991
NISSAN TRUCK
Air Conditioner Compressor Will Not Run
The Air Conditioner Compressor Will Not Run Unless I Ground One Of The Wires Where The Low Pressure Switch Connector. I Have Already...
Asked by
Glenn Ketchum
5 IMAGES
1995
NISSAN TRUCK
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
