1990 Nissan Truck Won't start
CODAVIS
  • 1990 NISSAN TRUCK
  • 4 CYL
  • 150,000 MILES
My 1990 Nissan Pickup won't start. It tries to start when I first turn it over. Then after that, it just turns over. I am not sure what to check. The spark plugs look fine but two of the cylinders appear flooded after continuous turning over. Maybe it is the coil? What do you think?
Tuesday, June 2nd, 2009 AT 12:34 PM
JASONRAY
  • 213 POSTS
We should probably start by checking fuel supply/pressure. Which 2 cylinders is it that appears flooded? Once you've made sure you have plenty of fuel, then we'll check for 'spark'.
Tuesday, June 2nd, 2009 AT 1:26 PM
CODAVIS
  • 5 POSTS
I think it was 3 & 4 that were fouled
Tuesday, June 2nd, 2009 AT 3:39 PM
JASONRAY
  • 213 POSTS
Does that one have 8 spark plugs or just 4? Some had a 'leading' and a 'trailing' spark plug in each cylinder. If the plugs are getting fouled, that probably means they either aren't firing or they're firing at the wrong time. But, it probably means that the cylinder is getting fuel. Is there any way the plug wires to those two cylinders got switched by any chance? Double check your firing order and make sure they are on the correct cylinders. You may need to check the compression on those two cylinders. The timing belt may have broken. Can you take the oil fill cap off and see the rocker arms? If so, have someone spin the motor over while you watch the rockers. Are they moving? If not, the timing belt isn't in tact.
Tuesday, June 2nd, 2009 AT 4:01 PM
CODAVIS
  • 5 POSTS
It has 4 spark plugs. On the other side of the engine, it has what looks like fuel injection.
Tuesday, June 2nd, 2009 AT 4:42 PM
CODAVIS
  • 5 POSTS
It just started raining in buckets so I will have to get back to you. I was going to check the rocker arms.
Tuesday, June 2nd, 2009 AT 4:44 PM
CODAVIS
  • 5 POSTS
One more thing. The spark plug wires are numbered one through four so they shouldn't be switched.
Tuesday, June 2nd, 2009 AT 4:49 PM
JASONRAY
  • 213 POSTS
OK, I've just seen it too many times, sometimes people start poking and prodding and end up switching the plug wires around and not remembering how they are supposed to be. But if that's not the case, we'll proceed. When it stops raining, check the rockers while someone spins it over. See if any of the valve train is actually turning while the motor is spinning. If not, we'll put a timing belt on it. Just get back with me. I'm here just about all the time.
Wednesday, June 3rd, 2009 AT 8:25 AM
