1990 Nissan King CAB
GSTANLEY29
  • 1990 NISSAN TRUCK
1990 Nissan King Cab truck, 68K miles. After 1/2hr to 1 hr drive when turn off it will not restart. If left for 10 to 15 minutes it will start again. Have change the starter but still have the problem. Any suggetions?
Greg
Thursday, June 14th, 2007 AT 1:02 PM
DONNY BRYSON
  • 13 POSTS
Check the coil packs
Monday, June 18th, 2007 AT 6:48 PM
DONNY BRYSON
  • 13 POSTS
Also check to see the temp. Is it over heating?
Monday, June 18th, 2007 AT 6:51 PM
PWHITE23
  • 5 POSTS
I would check your starter relay. Older Nissans are notorious for them failing periodically. It is under the hood on the inner fender skirt. You can jump out the relay to test the next time it fails or get a friend to tap on it while you start it. Good luck.
Wednesday, June 20th, 2007 AT 8:26 PM
