1990 Nissan Truck Blowing white smoke that smells of gas
1990 NISSAN TRUCK
145,000 MILES • 6 CYL • 2WD • MANUAL
LOONATIC72
My 90 nissan p/u died one day and wouldnt start. When I came back to it an hour later it still didnt start until I floored the pedal and then blew a big cloud of white smoke and smelt of gas. I changed the engine temp. sensor ang it'll start right up but blews white smoke and stinks bad of gas. I just changed the TPS and that didnt help either. The truck seems to run great other than the bad gas smell.
thanks in advance
Sep 9, 2008 at 10:28 AM
BLACKOP555
  • 10,386 POSTS
first ill have to ask whens the last time you change the fuel filter. and secondly have you noticed a low transmission fluid level or a low antifreeze/coolant level?
Sep 9, 2008 at 12:18 PM
LOONATIC72
I have replaced the fuel filter first cause I thought that was the problem. I havent crawled under it to check the fluid on the tranny being that its a manual and is shifting fine. The oil & antifreeze level is fine I checked it over good cause I thought I might have blown the head gasket.
Sep 9, 2008 at 12:54 PM
BLACKOP555
  • 10,386 POSTS
sometimes excessive water in the gas can cause a very gasy smell and excessive white smoke.
Sep 12, 2008 at 10:23 AM
