i was wondering how to bleed the transmission for a 1989 nissan truck.
Monday, September 22nd, 2008 AT 8:40 PM
MECHANIC
You don't bleed a manual transmission-you just drain and fill it with 80W90 weight gear oil.
SPONSORED LINKS
Monday, September 22nd, 2008 AT 9:11 PM
D3R0CK
MEMBER
I meant to ask you how to bleed the clutch on a 1989 nissan truck, 5 speed manual.
Tuesday, September 23rd, 2008 AT 11:24 AM
MECHANIC
Okay I understand make sure the clutch master cylinder is full -find the slave on the bottom near the transmission -then you bleed like doing the brakes. You pump a few times hold it down-open bleeder valve wait till bubbles/fluid stop then close the bleeder repeat this 2X. If its not improving after 3X the clutch master cylinder could be leaking internally-needs replacement.
Tuesday, September 23rd, 2008 AT 12:33 PM
D3R0CK
MEMBER
Ok, could you tell me what size wrench I will need, or what tools for that matter. Also, is there any way you could send me a picture so I can be sure i'm looking at the right place.
