1996 Nissan Truck
1996 NISSAN TRUCK
DAN1832
Engine Mechanical problem
1996 Nissan Truck 4 cyl Two Wheel Drive Manual
what are the torque settings for my 96 pickup engine?
Jan 3, 2009 at 9:40 PM
BUDDYCRAIGG
  • 2,262 POSTS
for what bolts?
Jan 3, 2009 at 10:08 PM
DAN1832
head bolts main bearings rod bearings intake and exaust manifold
Jan 3, 2009 at 10:56 PM
BUDDYCRAIGG
  • 2,262 POSTS
head bolts
step 1 22ft.lbs
step 2 58ft.lbs
step 3 loosen all bolts
step 4 22ft.lbs
step 5 plus 80-85 degrees
main bearings
34-38ft.lbs.
in 2 to 3 steps, strating in the center and working out.
rod bearings
10-12ft.lbs. plus 60-65 degrees
intake
12-15ft.lbs.
exaust manifold
14-17ft.lbs.
Jan 3, 2009 at 11:09 PM
DAN1832
thank you
Jan 4, 2009 at 8:55 PM
