1985 Nissan 720 Pickup 4cyl 8plugs/ reg CAB / 4WD
GUNTER20
  • 1985 NISSAN TRUCK
I just purchased this truck and was wandering if I could add power steering since it doesn't have it?
I was also needing to know were to get interior parts ie dash pad, sun visor hooks ect.
Wednesday, May 16th, 2007 AT 2:55 PM
KAMO
  • 47 POSTS
Yes you could add power steering, you just need to retro fit the correct parts. I believe the diesel 720's had power steering, you may be able to use the power steering assembly from that. As far as the correct parts to use, I could not tell you.
As far as interior parts, go check out your local salvage yard or search the web. Sites like www. Car-parts. Com or onlyfactoryparts. Com are great sources for hard to find OEM parts.
Wednesday, May 16th, 2007 AT 3:26 PM
